Dadi
- 17.05.2020
- 4
- Philips 55PFS8159/12 Bootloop Logo
Hersteller: Philips
Typenbezeichnung: 55PFS8159/12
Chassi: QV14.1ELA
kurze Fehlerbeschreibung (2-3 Worte): Bootloop Logo
Ja, als PDF
Hallo. Der Fernseher bringt das Philips Logo und bootet dann in schleife ständig neu. Komme nicht ins Recovery Menü und das Gerät reagiert nicht auf die Fernbedienung um ins Service Menü zu kommen.
Habe die Boot Log über die Service Schnittstelle ausgelesen:
[11.912805] TZ CPU0 ERROR[tz_sw_verify_image] verify image fail, src=0x19c00000, len=0x02738c00, dst=0x19c00000GIH magic num is not correct (0x482a4d49 != 0x00010080)!!!
recovery partition image is not proper !!!
****** BOOTLOADER_NORMAL_RESET_STAGE********
Send WARMUP_1_RESP.
Answering WU_FROM_DDR_OFF1.
[ 694618]I(SM): SM:Enter warmup state
[ 694622]I(SM): ******leave flow ---Sysreset to FastActive---
Send FAST RESET command to SM
[ 694821]W(SM): %%%%SM:Msg FAST SYSTEM RESET%%%%
[ 694825]I(SM): ******enter flow ---Sysreset to FastActive---
[ 694832]I(SM): peripheral_assert done
[ 694835]I(SM): soc_assert done
[ 694838]I(SM): mv_sm_power_socpoweroff done
[ 695143]I(SM): mv_sm_power_socpoweron done
[ 695203]I(SM): peripheral_assert done
[ 695207]I(SM): soc_assert done
[ 695303]I(SM): peripheral_deassert done
[ 695306]W(SM): ### Wake Up Reason 0x0[ 695310]I(SM): soc_deassert done
[ 695313]E(SM): mv_sm_timer_start - arg check fail!
/_S?àḞb[ 0] sys_init start. boot_strap=0x00000514 (source=eMMC), boot_state=0x7
image verify fail!!!
remote:ea84e1950f9bbe56d176bbfa1ae646ae5750a3cabda467c4b16bc4939c57926e
local :
tzk image verify fail.
[ 415] image verified, start at 0x00920000...
tz kernel starting... MV88DE3114(BG2Q)-A1 total 4 cpus, v2.0.0.21, Aug 5 2014 14:39:52
0213[ 471] start_bootloader
UẂULAUNCH_ITM is set to zero
board_number = 2
uiBoot = 7
I2C switch set as 0
I2C switch set as 1
--------- I2C Initialization ----------
I2C_INIT: I2C-2 bus
I2C_INIT: I2C-1 bus
I2C_INIT: I2C-0 bus
DDR reg 0xF7CB0BAC value : 0x00021421
DDR reg 0xF7CB0C00 value : 0x00004031
leakage info 400.
set Vcpu to 1300mV, default setting by hardware.
core from 1200 to 1150
set Vcore to 1175mv
set Vcore to 1150mv
set Vcore to 1150 mv.
SPLASH: wakeup_reason : 0
****** SPLASH ENABLED FOR Recovery********
flash_ts_init() success.
RDKDMP BG2Q [Oct 27 2017 18:04]
Pinmux configuration:
GSM 0xf7fcd040 0x009c0261;
0xf7ea0014: 00000072 00240611 00000253 1249008a
0xf7ea0028: 01249492 00000048 1ca54009 0430e44d
0xf7ea003c: 00000000 00000000 0000001f 63c06a52
Clock configuration:
VCO_B frequency 1620
AVPLLB[4] frequency 300
AVPLLB[5] frequency 800
AVPLLB[6] frequency 1680
AVPLLB[7] frequency 610
cpuPll frequency 1200
memPll frequency 1500
sysPll frequency 800
dClk frequency 375
cpuClk frequency 1200
sysClk frequency 400
drmClk frequency 400
cfgClk frequency 100
gfxClk frequency 400
zspClk frequency 400
perifClk frequency 200
pCubeClk frequency 610
vScopeClk frequency 610
nfcEccClk frequency 100
vppSysClk frequency 400
appClk frequency 800
gfx3DCoreClk frequency 420
gfx3DSysClk frequency 400
arcRefClk frequency 400
vipClk frequency 400
sdioXinClk frequency 200
sdio1XinClk frequency 200
gfx3DShClk frequency 420
avif0Clk frequency 300
avif1Clk frequency 300
[00,sd00] bootloader: part1(start=0, blks=1, version=201710271804), part2(start=0, blks=1, version=000000000000)
[01,sd01] fts: part1(start=32, blks=32, version=201710271804), part2(start=32, blks=32, version=000000000000)
[02,sd02] recovery: part1(start=64, blks=120, version=201710271804), part2(start=64, blks=120, version=000000000000)
[03,sd03] tzk_recovery: part1(start=184, blks=8, version=201710271804), part2(start=184, blks=8, version=000000000000)
[04,sd04] factory_setting: part1(start=192, blks=128, version=201710271804), part2(start=192, blks=128, version=000000000000)
[05,sd05] itm: part1(start=320, blks=128, version=201710271804), part2(start=320, blks=128, version=000000000000)
[06,sd06] boot: part1(start=448, blks=24, version=201710271804), part2(start=448, blks=24, version=000000000000)
[07,sd07] tzk_normal: part1(start=472, blks=8, version=201710271804), part2(start=472, blks=8, version=000000000000)
[08,sd08] system: part1(start=480, blks=1600, version=201710271804), part2(start=480, blks=1600, version=000000000000)
[09,sd09] user_setting: part1(start=2080, blks=960, version=201710271804), part2(start=2080, blks=960, version=000000000000)
[10,sd10] cache: part1(start=3040, blks=896, version=201710271804), part2(start=3040, blks=896, version=000000000000)
[11,sd11] firmware: part1(start=3936, blks=64, version=201710271804), part2(start=3936, blks=64, version=000000000000)
[12,sd12] factory_data: part1(start=4000, blks=32, version=201710271804), part2(start=4000, blks=32, version=000000000000)
[13,sd13] userdata: part1(start=4032, blks=3328, version=201710271804), part2(start=4032, blks=3328, version=000000000000)
get macaddr from fts: 1c:5a:6b:XX:XX:XX
macaddr=1c:5a:6b:XX:XX:XX
get_reset_msg,1262: sysreset, need to get reset_msg_extra_size=0
tzk boot with recovery mode
Was könnte das Problem sein und wie kann man es lösen?
Bin dankbar über jeden Ratschlag.
Vielen Dank.
MFG
Chassi: QV14.1ELA
Ja, als PDF
Send WARMUP_1_RESP.
local :
board_number = 2
uiBoot = 7
I2C switch set as 0
I2C switch set as 1
I2C_INIT: I2C-2 bus
I2C_INIT: I2C-1 bus
I2C_INIT: I2C-0 bus
leakage info 400.
set Vcore to 1175mv
set Vcore to 1150mv
dClk frequency 375
Vielen Dank.
MFG
